I have a hole diameter with limit tolerancesthat I am trying to display as a note in another dimension. Initially the limit tolerance appeared in the noteas:
Has anyone else ever ran into this problem or have any suggestions on how to fix? I attached a screen shot of the limit tolerance in a note and as a standalone dimension.
Cole
Cole,
Your terminolgy is throwing me a bit. You stated you displayed as a "note". Did you mean a shown dimension with tol_display activewith a symbol typed in the properties box or some other method? How exactly are you constructing (or showing)the string of text in you attached doc?
Dean,
I am dimensioning a counter-bore and thru hole together. I am using theshown dimension for the counter-bore and going to the display and adding a reference to the shown counter-bore depth and the thru hole dimensions. The display text looks sometihng like:
