Limits Dimension (Side by side vs Above/Below)
SOLVED
Highlighted
Sapphire I
What config in the drawing config file controls whether a "Limits" dimension is Lower-Higher (side by side) vs Higher/Lower (above and below)?
1 ACCEPTED SOLUTION
Highlighted
Re: Limits Dimension (Side by side vs Above/Below)
ProWorkAround:
Making sure that the default_tolerance_display_style: std_asme
A new dimension was created and now its hyphenated.
Then delete  erase old dimension (in case the stacked version is used in another instance and will disappear from those instances).
12 REPLIES 12
Highlighted
Looks like this:
Highlighted
Oddly enough, it doesn't seem to be doing anything in my test drawing.  Hmmm.  (Creo Parametric 6.0.5.0)
Highlighted
Both drawings had default_tolerance_display_style: std_asme
Highlighted
Highlighted
Server reboot causing other issues. I'll have to get back to this later.
Highlighted
It looks like this option might be the one you want to mess around with. I did a quick test and it looks like the orientation of the dimension matters. This seems a little odd and definitely inconvenient. There's also separate settings for the other types of dimensions.
Ty
Highlighted
TDaugherty, What are you opening to get that pop-up window?
Highlighted
In drawing mode:
File > Prepare > Drawing Properties > Detail Options
This menu is where you can create and export dtl files.
Highlighted
Both of my drawings have default_lindim_text_orientation: horizontal
Highlighted
Doesn't this config have to do with the text being inline with, above or below the leader?
Highlighted
To be honest, I haven't done enough testing on this to be sure of anything at this point. I just created a dimension and set up a limits tolerance. I then adjusted the orientation and I saw the limits change from being stacked to being hyphenated. I too would be very surprised if this option controlled the tolerance display but it did seem to have an effect in the quick test I ran.
I've got some more time now. I can jump back in and see what I can find.
Ty
Highlighted
ProWorkAround:
