Loading color.map...
Newbie
I posted this in the systems exploder but got no responses, so I thought I would try here.
I am on Creo 2, build 030 and trying to get my color.map to load. I have the files color.map,color.dmt and appearance.dtmin the D:\cad\creo directory. My personal config.pro contains "pro_colormap_path D:\cad\creo".Upon opening Creo and looking at all options in the cofiguration editor I see two lines in order:
pro_colormap_path $PRO_LOCAL_DRIVE\cad\creo
I believe the first line is the "corporate" config.pro and the second is my personal one. Also, $PRO_LOCAL is set to D:. Unfortunately, when I go into RENDER and look at My Appearance, I do NOT see my color.map/appearance.dmt colors. I have to manually load this file each session, which works just fine so I know the files are okay, they just won't load automatically. What am I doing wrong?
thanks in advance...
[External] Loading color.map...
I think it started with WF2 but color.map is no longer used. appearance.dmt is the only file that gets loaded in. I am not positive, but I believe that if you want to name your .dtm file something other than appearance.dmt you have to put that it in file path for pro_colormap_path. (ie: D:\cad\creo\color.dmt)
Christopher Rees - Mechanical Engineer - ISR Systems
UTC AEROSPACE SYSTEMS
100 Wooster Heights Rd, Danbury, CT 06810 U.S.A.
RE: Loading color.map...
Might not be that clear, but I DO have an appearance.dtm file in the directory I am setting for pro_colormap_path. I actually started with the color.map file, then made a color.dmt and an appearance.dtm file along the way of trying to get it to load and reading thru posts here...
