MBD: Custom Symbol In Drawing Notes
dsondenaa
Is there anyway to input a custom symbol into notes in a model? I can get a standard symbol to work (Standard1) but I cannot get a custom one to work using the &sym(Symbol_name) command.
1 ACCEPTED SOLUTION
look into https://www.ptc.com/en/support/article/CS69664 document.
Martin Hanák
Martin Hanák
dsondenaa
(To:MartinHanak)
Thank you we figured out you had to first add it into the model before you could add it into a note. I wish this would be fixed by PTC
