Hi friends,
I am new to this comunity and new to creo 2.0 as well.I am trying out a assembly model and want to export it to ansys14 as igs file.I found somewhere that ansys takes single part model and hence I have to merge the parts of the assemble.Although I tried to follow a link http://www.codexcreo.com/component_merge.html to settle the problem but it did not help me much.
Also,I tried to create a single part in creo but whenever I export it to ansys,it automatically break into multiparts(as if I created an assembly).Please friends,if anyone can help me...how do I tackle this problem
Thank you in advance
Shikha Bhuyan
One way to achieve what you want might be to generate a Shrinkwrap (Save A Copy...) of your assembly, then open the Shrinkwrap and save that as an IGES.
Make sure you adjust the options to retain all the important detail of your assembly.
Hello and welcome to the community,
Try to open your assembly, save a copy, iges, pick a name then OK, then in the next window on thefile structure choose One Level option. Try this and send feedback
Hugo
