Missing GD&T on PDF from drawing export
Hello, I am newer to CREO 4.0. When I need to export my drawing to a PDF, my GD&T symbols go missing. Would there be something I need to add in my configuration editor from options? The only way I have found to fix this is to export as a TIFF file.
36 REPLIES 36
Re: Missing GD&T on PDF from drawing export
please attach picture of Creo window and picture of window showing PDF contents.
MH
Martin Hanák
Hey Steven,
Correct. Every symbol (perpendicularity, concentricity, etc.), it does not show up. See the image.
Mark,
Please try to move the GD&T symbol in separate layer and use Layer save status before exporting to pdf
This is from the drawing view.
Steven's settings show that he's using Stroke Non TrueType Fonts - are you using that, or Stroke All Fonts?
These symbols probably do not exist in TrueType fonts, so you need to allow Creo to 'plot' them directly which is what these options do.
Hey Steven,
My settings match yours, except under fonts: I have USE TRUE TYPE FONTS.2017-04-27 08_37_00-PDF Export Settings.png
I created a new layer, however, I am not familiar with "layer save status" where do i find that?
set Stroke All Fonts option and export PDF.
MH
Martin Hanák
Go to layer tree, RMB and then you will see third last option is Save status. See image
