Model Annotations - Creo 3
SOLVED
Highlighted
Newbie
Hi All,
Just finished installing Creo 3.
When working on a drawing containing views of an assembly I am now unable to get any on the centre lines to show up.
Normally I would highlight the view, select 'Model Annotations' and one of the tabs would show me what centre lines where available to use.
Now all I get is a message saying I cant show them??
Is this a con-fig setting that I have wrong?? Any ideas??
Thanks, James.
1 ACCEPTED SOLUTION
Re: Model Annotations - Creo 3
Select the part or feature in the model tree, then rigth click Shoe Model Annotations and you should be able to select the ceneterlines.
3 REPLIES 3
Not having Creo 3 loaded yet, it is difficult to troubleshoot issues such as this.
However, I would suggest that any negative user experience should be reported by creating a support case.
PTC needs to know the pain users are feeling, even if it is something very simple or just plain annoying.
Of course, sharing issues and resolutions with the community is always appreciated.
Donald, Nice one, just what I needed, works perfectly!!!
Thanks, James.
