Modifying lengths of cables
SOLVED
Highlighted
Regular Member
One of our engineers is having difficulty modifying a cable length.  He watched several online tutorials in which the video shows you can just click a length dimension in the _MFG file, but every time they attempt to change it, they receive the following dialog message:
"Can not modify length of flattened cable portion."
We're completely green when it comes to cabling and were hoping that this would be a simple modification.  Are we just missing something obvious?  We're in Creo2.0 M200.
Tags (2)
1 ACCEPTED SOLUTION
Re: Modifying lengths of cables
We figured it out.  Turns out we were missing a skeleton file.  Once we modified, the length updated.
1 REPLY 1
LiveWorx Call For Papers Happening Now!
