Move Radius in Advanced Pipe plus centerline show per view
amedina
Usually we use the Advanced pipe feature to create pipes. The center line is
put in a layer and hidden.
A user wants to used a single radius pipe on a drawing and on a particular
view show the radius dimension. It seems that the radius dimension is locked
to the first bend on the pipe. Is there a way to move it to another bend? I
seem to recall that there was such a way.
Now with the pipe on the drawing he wants to dimension to the centerline and
so he wants it shown on particular drawing views but he wants to have an iso
view that does not show the centerline.
We used to forget about and hide the centerline and add our own radius line
to show on a local section view. Well that sounds a little involved and it
is. However if we had a way to keep that centerline where we want it and
remove it where we don't, that would be great.
Any ideas? Thanks for the help!
regards,
Alfonso
0 REPLIES 0
