Moving section views in drawing
dougkeuneke
1-Newbie
I have never found a way to move section views to another location (other than the projection path) and keep the section arrows and
name. Converting to general allows the move but removes the name/arrows. Any suggestions?
Doug Keuneke
Manufacturing Engineering
United Space Alliance
Kennedy Space Center, Fl
321-867-2653 work
321-501-0643 cell
3 REPLIES 3
rdevaux
6-Contributor
(To:dougkeuneke)
I would like to make a copy of an existing assembly which has drawings
associated with it. Problem is that I can't seem to get the drawing to
copy with the assembly. Having always used Intralink, I'm not sure if
it's something I'm doing wrong. I tried PTC support, and they are
telling me that I need to open each individual part, and do a rename of
each part, which I told him was absurd. It could take days to rename a
large assembly! So I'm hoping somebody came walk me though it.
Here are the steps I've tried.
1.) With the assembly open, I select File>Save a copy
2.) I give the assembly a new name
3.) This brings up a dialog screen with all the parts of assembly
shown. The check box for "Copy Drawings" is checked.
4.) I create new part names using the Template option.
5.) I select "Generate New Names"
6.) I select "Save Copy".
Pro/E generates the new part files, but it does not make a copy of the
drawing.
I'm trying to do this in Wildfire 5.0 M060 loaded on Windows 7
Rob Devaux
Tool Design Supervisor
ABA-PGT, Inc.
10 Gear Drive
Manchester, CT. 06042-0270
United States of America
(860)649-4591 ext. 120
fax (860)643-7619
rdevaux@abapgt.com
www.abapgt.com
Open the drawing and do a FILE, BACKUP.
Bob
rdevaux
6-Contributor
(To:dougkeuneke)
Well I want to thank everybody for the quick replies. The reason the
drawings were not being created was because the drawing did not have the
same exact name as the assembly I was trying to duplicate. Seems kind
of silly that they have to be the same name, but it's a problem I can
work with until we're back up on Intralink.
Rob
