Multi-model drawings
Highlighted
Topaz II
In 2001, is there away to force secondary models in a multi-model drawing to regenerate from within the drawing?  Now when I hit regenerate - model, it only regenerates the active model.  Any other models are not regenerated unless I open them and regenerate them.  I can't even see a way to regenerate them from within the drawing.  I'd like all drawing models regenerated, is this possible?  Does WF and WF2 act this way too?
Doug Schaefer
LinkedIn
Highlighted
Re: Multi-model drawings
In Creo i have the same problem. No way to solve this problem ?
Highlighted
There isn't a command to regenerate each model in the drawing at once.  You can find the models that aren't up to date with the status color in the model tree's model selection list, use the model tree to switch to the out-of-date model, and Regen it, repeat for each in turn.  You could whip up a Toolkit (or other programmatic API) function to do it, but that's work.  For a command in the UI for it, you'll need to ask PM for an enhancement.
