Multiple ass'y views on a drawing - Summary (wow that was fast)
Newbie
I feel so dense (DUMB) sometimes. I knew it was extremely easy, only I
haven't used it in quite a while (use it or loose it <g>).
As for the snapshot question:
It's now called "Convert to draft entities" and is found under the EDIT
menu. (Easy!)
As for the question about using family tables or drawing states:
Family table instances were the way to go. Each instance has the
assembly in a different position.
It's done the same way as in version 2001, only how you get there is
slightly different from before:
The steps were:
1. RMB on the drawing sheet
2. Properties
3. Drawing Models
4. Add Model
5. Choose model from the list
6. Choose the family table instance (e.g. open or closed)
7. Choose a simplified rep (if any)
8. Place the view on the sheet.
Worked like a champ. Thanks.
Special thanks to: Bob at Parker and Erik at GWLISK for going the extra
mile.
The information contained in this electronic mail message is
privileged and confidential information, may be subject to the
attorney-client privilege and is intended solely for the use of
the addressee. If you are not the intended recipient, any
disclosure, copying, distribution, or the taking of any action
in reliance on the contents of this message is strictly
prohibited. If you have received this message in error, please
notify me immediately.
RE: Multiple ass'y views on a drawing - Summary (wow that was fast)
Here's a random Friday question for you...
What is the correct past-tense form of snapshot?
(yes, I know it's still Thursday)
-Brian
I think it is an expletive as mine are usually blurry, out of focus and
with the head cut off!
Digital snapshots at least give you another chance.
_____
