Multiple jogs on a single witness line
SOLVED
Highlighted
Garnet
What is the trick to add multiple jogs on a ordinate dimension. I can add one, whenever I try to add a second jog the second jog starts at the vertex of the first jog and not where I pick on the line. I am on Creo 4
1 ACCEPTED SOLUTION
Highlighted
Re: Multiple jogs on a single witness line
see attached video.
Martin Hanák
Highlighted
see attached video.
Martin Hanák
Highlighted
Thank you Martin, I knew it had to be something easy!
