"sekar ramalingam" wrote:
Hi Balaji Use the option dual_digits_diff to control the primary dimension and secondary dimension digits. use the positive value in that option, you will get addition of digits in secondary dimension compared to primary dimension. If you negative, the reverse will occur regards sekar.r
