Note Properties in Creo 3 not the same as Creo?
SOLVED
Newbie
We use Creo at work however at school we have creo 3.  One of the most annoying issues I have is when I make a note, in Creo 3 I type right in paper space.  However in Creo a Note Properties box comes up where I can type my text in there.  Is there a way to get the Note Properties box to come up in Creo 3?
Text box below in creo.
1 ACCEPTED SOLUTION
Highlighted
Re: Note Properties in Creo 3 not the same as Creo?
This properties box was removed when Creo 3.0 was first released.  Due to customer complaints, it was added back into the Creo 3.0 M100 maintenance release.  If you are running M100 (or later), you can right click on the note and click "properties" to open this dialog.
6 REPLIES 6
Highlighted
Tom,  How do you go about getting the maintenance release?
If it is the academic version on a school server, the administrator will need to request the new build from PTC.
It can be downloaded from PTC's website by anyone with a current maintenance contract (or educational contract in the case of a school).
I have downloadable edition that is used for school.  Sorry for the confusion.
Why didn't they add back the option of double clicking on the note to get the properties box to open?
LiveWorx Call For Papers Happening Now!
