Notes for drawings that show minimum dimensions
jwagh
We would like to clarify our notes a bit concerning what dimensions the drawings should show and what the 3d model would be used for. We would like the drawings to only show critical and inspection dimensions while the rest of the geometry would be created from the 3d model. If your company uses a similar system, would you mind sharing your note that you use?
Thank you!
0 REPLIES 0
