Old Crusty Brain Syndrome...need help with a Config option
DeanLong
I cannot remember/find the option that allows the dimension height/font to be increased on the screen in part and assembly mode. I did this in 3, 4 and 5 during the period my eyesight decided to head south.
Can you guys remember what that oneis?
7 REPLIES 7
MikeLockwood
22-Sapphire I
(To:DeanLong)
I like this subject line (old crusty brain syndrome) - may use it occasionally 🙂
BillRyan
(To:DeanLong)
These are the lines I added to my config for Parametric 2. (Thanks to the PTC training session I attended down here in Dallas!)
!====added 3/2014 to control fonts in Creo UI.
menu_font aerial, bold, 10
model_tree_font aerial Narrow, 2
Try TEXT_HEIGHT_FACTOR
Bigger numbers = smaller text
Also, Pro/E may need a reboot to take effect.
x
Thanks....All
FYI...TEXT_HEIGHT_FACTOR is not shown as a config option
Correction.....I am wrong....David Schenken is correct. TEXT_HEIGHT_FACTOR is the correct config option.
It is a hidden config option which is why I could not simply click "find" and well, find it. Thanks to David for saving an old(er) man's eye for a little while longer.
