Options Descriptions List?
SOLVED
Amethyst
Is there a list of description options somewhere for CP4 M010?
Or is it possible to export config options with the description included?
Creo 4.0 / M060
1 ACCEPTED SOLUTION
Re: Options Descriptions List?
Config option in PDF format can access from File > Help > Reference > Configuration options
OR it (configoptions.pdf) is available under installation directory of Creo 4.0\datecode\\Common Files\help\reference\pma\usascii
I use Olaf Corten proesite to find config options. He lists hidden options also, although they typically don't have descriptions as to what they are used for.
http://www.proesite.com/UTIL/view_config.html
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
There is a config.pro table downloadable as a CSV file on the PTC web site under Creo 4 documentation.
