PCF options
SOLVED
Re: PCF options
Since it prints fine from Creo manager than the PCF is correct. Correct? I just want to verify that the issue is with a setting when printing from MS manager.
Re: PCF options
User began using Creo print manager and that seems to resolve the issue. Might be a problem with Windows settings for the printer.
Re: PCF options
I spent considerable time / effort on this with multiple companies.  Came to the conclusion that in general, it's better to get Print to PDF working from Creo, then have all users print from PDF.  There are some legitimate reasons to print directly from Creo but they are getting fewer all the time.
