I am working with Creo 4.0 M60
I am trying to paginate a hole table but am running into the issue of trying to "Set Extent". I get the error message "Could not set extent."
It looks like someone had the same issue 15 months ago with no solution:
... and here Martin talks about "Set Extent" which I cannot do:
https://community.ptc.com/t5/Detailing-MBD-MBE/Repeat-Region-table-fitting-on-the-sheet/m-p/619460
The help file talks of "Set Extent" too:
Thanks, Dale
Caught a specific wording:
If I create the table with the number of rows I want, that works, but it doesn't see to allow me to change it after it was made (or I can't get back to the menu to set the number of rows).
Dale
This article is for an older version, but might be worth trying:
It mentions that Paginate with repeat region table.
Is a "Hole Table" considered a repeat region table?
Dale
