Parameter within Symbol
Level 6
Can anyone help with creating a symbol that is drawing parameter driven? I have a note with variable text that I would like to drive with a parameter without typing the parameter each time I place the note.
To be specific, I have a revision parameter at the drawing that is Dwg_Rev and I would like it to drive the symbol each time it is placed. Adding the parameter ( &dwg_rev ) does not work similar to notes for symbols. Or so I think.
Re: Parameter within Symbol
I am no expert in symbols but I do remember something about using a different parameter delimiter (not &).
I could be way off but someone will correct me if so.
I was guessing this is so as well. Thanks for the input.
