Pen table and line thickness
SOLVED
Regular Member
I am trying to setup a pen table but every time I export to pdf the line thickness doesn't change. Here are the steps that I was doing.
Options> Configuration Edition, then I changed the following options.
pen_table_file C:\Users\Raaid\Desktop\Matrix\DXF\table.pnt
pdf-use-pentable yes
use_8_plotter_pens yes
Save the config.pro file into my working directory, which is also where the pen table is saved.
The pen table:
pen 1 thickness 0.03 cm; color 0.0.0.0.0.0
pen 2 thickness 0.013 cm; color 0.0.0.0.0.0
pen 3 thickness 0.013 cm; color 0.0.0.0.0.0
pen 4 thickness 0.013 cm; color 0.0.0.0.0.0
pen 5 thickness 0.03 cm; color 0.0.0.0.0.0
pen 6 thickness 0.013 cm; color 0.0.0.0.0.0
pen 7 thickness 0.013 cm; color 0.0.0.0.0.0
pen 8 thickness 0.013 cm; color 0.0.0.0.0.0
Does anyone know why this is not working?
Re: Pen table and line thickness
color 0.0.0.0.0.0 ... is nonsense
use ... color 0 0 0
Martin Hanák
the only problem I see is ... pdf-use-pentable yes
Correct config.pro option follows
PDF_USE_PENTABLE  yes
Martin Hanák
Thanks for the reply Martin. That didn't work as well.
use ... color 0 0 0
Martin Hanák
Thanks a lot for the help. It's finally working!
