Please Help!!
rturner
2-Guest
Please Help!!
When I am detailing parts on drawings, the dimensions that have lost their references or "fallen off" are the same colour as the regular attached dimensions, so I get no "at a glance" warning of problems until I have printed the drawing out - where the unattached drawings show as thick black lines. Is there a way of changing the colour to highlight the unattached dimensions on screen? I thought this feature was hard coded in the software and they are generally purple but... alas, it is not can someone please steer me in the direction of changing the colours. I am using Creo Parametric 2.0
1 ACCEPTED SOLUTION
Russel,
modify Graphics > Manufacturing volume color.
Martin Hanak
Martin Hanák
Russel,
click File > Options and select System Colors item in dialog box.
Martin Hanak
Martin Hanák
Hi Martin,
Thank you for the swift response. I have looked at the system colors, but I dont know what setting differentiates between the attached dimensions and un-attached dimensions
Regards
Russel
Russel,
Martin Hanak
Martin Hanák
& THERE IT IS!! thank you so much! very helpful. cheers Martin
