Problem with Repeat Region
jvadalia-2
11-Garnet
Can anyone guide to the options available in Repeat Region?
I want BOM where all the PARTS should be in BOM and not a single Assembly.
Also want all components of the sub-assemblies of top-level assembly.
I know the option of "recursive" and "filter"
But i want that Table.tbl file to be saved for future uses.
Right now when i am saving the table file after applying all settings like recursive and filter by rule "&asm.mbr.type==PART*
Next time when i use that table file. It only shows the PARTS of Top level assembly. And all sub-assemblies along with it parts get filtered out.
So every time i have to work with BOM for the same.
And everytime to identify the PART/ASSEMBLY i have to again add 1 column of &asm.mbr.type (Unwanted) and then i start to set default all settings to BOM and again have to apply the settings.
Can anybody help here?
I can't see any problem ... see attached files created in CR2 M070.
  1. I created new drawing
  2. I set asm0001.asm as drawing model
  3. I imported table from table_2019-02-21.tbl
  4. table contains recursive BOM, indentation is set to 0, filter enables PARTs only
Martin Hanák
Martin Hanák
Hey Martin,
In this table bulk items are not populated.
Please help
Jignesh.
Hi Martin,
Bulk items are not populated in this table.
Please help
Jignesh.
bulk items are not displayed because of filter defined in the table ... see below
&rpt.level  > 1
&asm.mbr.type  == PART
You have to investigate, how to display bulk items ... please do it by yourself 🙂
Martin Hanák
