Hi again
I am using Pro/Program to generate a part, the problem that I have occurs when I ask for angle dimensions in the INPUT section, because I answer giving a dimension in degrees, but Pro/Program takes the answer as radians, destroying everything... When I go to fix the dimension, changing it manually, it has the right unit (degrees).
I don't know what to do to change the angle units in Pro/Program...
I hope you can help me solving this problem.
Thanks for your attention
I met this problem in Creo Parametric 2.0 M020. When you enter value using Pro/Program, then Creo applies radians instead of degrees on this value.
The problem is resolved in Creo Parametric 2.0 M110.
Martin Hanak
Which version and datecode of Creo you are working with?
Show a copy of the section of Pro/Progam that you think is making this change. By itself Pro/Program does not use radians.
Martin Hanak
That's a nice bug to add to software.
Thank you all for your inputs.
Martin I am using exactly that version and datecode of Creo (2.0, M020), so I think that's the problem.
A solution that I found was to ask for a parameter instead of the dimension, and then relate that parameter with the dimension. I think Creo only has that problem in the INPUT section.
Thank you very much!!
