Problems showing complete sheet when exporting to PDF
ptc-4926872
I have a drawing with several sheets in variable sizes, when I export them to PDF they appear incomplete only showing what I would think could fit in a Size E sheet. Any help for making the complete sheets apeear in the PDF?
Example: the first sheet is 34"height x 100"width, when I import it to PDF it only shows about half of it.
I am using Creo Elements/Pro
Thank you
Did you pick right paper size in pdf options? Like A4, A3...?
It doesn't show that option
Is the issue that the PDF is not adjusting sheet size for each drawing sheet individually?
I just did a quick test of a drawing with 2 sheets, size A and C. The PDF exported from the drawing will adjust and output the correct respective sizes for each sheet. The resulting PDF will have one sheet 22x17 and one that is 11x8.5.
I know you said "export" but can you confirm that exporting and not printing to PDF?
