I can get pview.exe to print Acad drawings with out any problem. My ACAD drawings have a Model and layout page. When I save the ACAD drawings I save them with the Model view active. So when I manually open the drawing via ProductView, it loads the Model Sheet. I can then manually print a single sheet by selecting "Selection" instead of "All". The issue I have is when I print via print command line it prints all pages when I just want the active sheet printed. Is there a way for me to print only the first sheet and not all of the pages via either the print command line option or using activeX if pview supports it? Thanks, John
