REPEAT REGION SYNTAX
bboman
8-Gravel
Does anyone know how to manually link notes and/or symbols to data within individual repeat region cells?
Is there a method I can use to find the data's syntax?
(I.E. parametric bom ballons)
1 ACCEPTED SOLUTION
TomU
(To:bboman)
You can create comments, but I don't think you can pull this information into a balloon or symbol.  To do that you probably would need to create an actual parameter in the model and then display it in the repeat region.
http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/detail/About_Adding_Comment_Cells.html
2 REPLIES 2
TomU
(To:bboman)
bboman
8-Gravel
(To:TomU)
Thanks for the link, Tom. I believe you are right. I messed around with custom balloons a bit, but was unable to do much else.
