Does anyone know how to manually link notes and/or symbols to data within individual repeat region cells?
Is there a method I can use to find the data's syntax?
(I.E. parametric bom ballons)
You can create comments, but I don't think you can pull this information into a balloon or symbol. To do that you probably would need to create an actual parameter in the model and then display it in the repeat region.
Thanks for the link, Tom. I believe you are right. I messed around with custom balloons a bit, but was unable to do much else.
