Does anyone know what this red and white diamond shape is and how to get rid of it? I just recently installed M150, Creo 3.0 and it has been there since. It wasn't there before the install. It is on my drawing view and model view and is just in the way. Any help is greatly appreciated.
Are you using a space pilot?
Yes.
That symbol appears while you are spinning the model. Normally it goes away when you stop but with a space pilot it says visible all the time. This was discussed previously here on the community but I can't find the topic at the moment. I believe if you unplug the space pilot it will go away.
This was a known issue and has been corrected in Creo Parametric 3.0 M160 and Creo Parametric 4.0 M040
Article 268780
