If I want to show a dimension as reference... do I have to add the parenthesis... or is there a better way?
You could use the Reference Dimension tool under the Annotate tab.
Gotta add 'em
Oh jeez... right in front of my nose!
Thanks!!!
In my defense, and clarification, you did say "show a dimension" as reference, not an "added" dimension. (I know - nit pickin)
The difference being obvious, model driven vs draft and it shows up in the drawing tree annotations as:
just sayin....
It would affect places like where I work that scans with modelcheck for added dimensions.
ron
Dan,
You may mark reply from James as correct answer and that information answered your query.
This was the answer I was looking for, but Ron's answer was also a good answer. Thanks guys!
