Relations ins a 2-D repeat region
Newbie
Hey Everyone:
I used relations many times with a simple region for assemblies, now I need to use them for a family table report. Does anyone have any good guidelines on how that is done? I have a pretty standard table that has a few string parameters as well as 5 dimensions. The table contains unpainted and painted components. The dimensions are shown only on components that are not painted. For all painted components, the dimension columns should be a dash.
I am looking on how I can specify the specific relationship when the report parameters for family table do not include the specific User Defined parameter option that the other parameter groups have. For example,
If paint == yes
table_dim_a = "-"
else
table_dim_a = a_text
endif
Table_dim_a will be the repeat region parameter, a_text and paint are both model parameters.
Thanks in advance!
Wes Holliday
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
