Anybody have a solution to the limited range for a repeat region? Range is 1 to 16384??? I am kind of inbarresed to tell my customer I can not use their BOM numbers. Web shows a work around but how do I get the balloons to read the perameter?
rep.index? or user defined parametric?
rep.index is what I am using.
I only know of a workaround, I'm not sure you can get by the range limitation.You can use your own parameter - but I'm sure that's not what you're after.
The only other thing you might be able to do is add a comment column and manually enter the index you want. I'm curious though, do you truly have an assembly with over 16,000 items - without the use of any subassemblies? Or are you using the 'flat' BOM listing all components at all levels in one BOM?
Good luck!
-Brian
Will you provide a pictrue of BOM
well I don't know the report paramatric what does "quan" means? if possible,provide the files
&rpt.index drives the colum & the balloons
