Repeat Regions
nhanratty
2-Guest
Repeat Regions
All
Just a question on default 'sorting' behaviour of repeat regions for BOM tables.
I have two repeat regions in a drawing neither of which have any 'sort' regions defined.
If I change the order in which the parts have been assembled in the model tree one of my repeat regions updates to reflect that order change which is what I want...but the second table does not.
Like I said neither table has a sort region defined and the second table does not have any fixed records/indices or regions so does anybody know why the parts in the second table are not following the order change?
Thanks for any suggestions.
Neal
1 REPLY 1
Scott
Spot on that’s the answer…thank you.
The table that wasn’t working had the attributes setting No Duplicates.
The table that is working has the setting No Duplicates/Level
Neal Hanratty
Engineering Systems and Standards Manager
Terex Materials Processing Group
T +44 (0)28 8241 8769
F +44 (0)28 8225 2740
M +44 (0)75 3495 2739
E neal.hanratty@terex.com<">mailto:neal.hanratty@terex.com>
