Report Generator for Model Manager / BOM Editor.
Newbie
The Report Generator is an add-on module to CoCreate's BOM Editor. With the Report Generator, access BOM data, format it, and save as PDF, HTML, Microsoft Excel.
Produce a well-formatted Bill of Materials (BOM)
  • Create dynamic BOMs in PDF, HTML, or Excel formats.
  • Print a BOM directly to a printer.
Design your own templates
  • Use any attribute available in Model Manager. Simply drag attributes into your template.
  • Use complex print when structures, e.g., “only print lines where the attribute type has the value Purchase part.”
  • Use calculations, e.g., total weight or total number of parts, based on attributes in the report.
  • Design different page-oriented sections like title, page header, column header, detail, column footer, page footer, and summary.
  • Use text masks, e.g., date could be represented as Wednesday 03 November 200” or as 03/11.
  • Use page-oriented texts like page 1 of 12.
Build from example templates
  • Generic: Reports all lines of the BOM onto the report.
  • DIN6771: Reports according to the DIN 6771A standard, for example.
  • Manufacture report: Outputs all manufacturing parts.
More information can be found at: http://www.xandorra.com/index.php/pdm/73 or give us a phone call at: +31 317-419164.
The datasheet for Report Generator can be downloaded at: http://www.xandorra.com/media/datasheets/Report_Generator_E.pdf
