Save as pdf - only save first sheet?
lylebeidler
We are currently running WF3, M160. We often have multi-sheet drawings
where sheet 2 is the dxf view for export to our CNC programming. So, we
don't want to export sheet 2 to the pdf of the production drawing.
However, the File > Save As > PDF dialog does not allow the user to specify
which sheets get exported - it automatically exports all sheets.
My question is this: is that behavior fixed in a later version of ProE? To
put in another way, what version would we have to upgrade to in order to be
able to specify that we only create sheet 1 in the pdf?
Thanks.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
I've never used the built in Pro/E PDF options due to limitations like
this.  If you print to a PDF, using Acrobat or some other 3rd party PDF
'printer', you can select what sheets to print.
Doug Schaefer
LinkedIn
dbailey-2
6-Contributor
(To:lylebeidler)
Hi Lyle
The option for saving individual sheets is available in wildfire 5
Best Regards
David Bailey
Design Director
Fort Vale Engineering Ltd
Simonstone Lane, Simonstone,
Lancs, UK. BB12 7ND.
+44 (0) 1282 687140
Fax +44 (0) 1282 687110
Lyle,
We have made a couple mapkeys to accomplish the scenario that you are
encountering. Then we made icons tied to the mapkeys and placed them on
the toolbar so they are only shown when viewing a drawing.
The only down side is that our PDF are not text searchable like you can
produce using the PTC icon.
Thank you,
Lance Lie
Sr Computer System Technologist II
310.334.1934 office
310.426.4968 cell
310-334.3078 fax
