Saves as Table file .xlsx
SOLVED
Highlighted
Newbie
Tags (1)
1 ACCEPTED SOLUTION
Re: Saves as Table file .xlsx
I believe you can save the table as a .txt or .csv.  Then just import that into Excel.
3 REPLIES 3
Thank you. It worked
Marcio,
You may mark Steve's reply as Correct Answer for the post.
LiveWorx Call For Papers Happening Now!
