Hi all,
In the past, to split up my hole tables I have used the method of selecting the table, clicking paginate. clicking set extend and selecting a row, then adding the segement. I am for some reason having trouble with the "set extent" step for some reason.
When I select the table, the click paginate, a message appears in the lower text manager saying "could not set extent" immediately. I click on the set extent button and click on a row and the message remains "could not set extend". I cant get it to let me set the extent for the life of me.
Any idea as to why this is all of a sudden an issue? I am on creo 4.0 and this has worked perfectly fine before (on same drawing even).
Thanks for any help,
Taylor
I wasn't able to set extents, but you can recreate the table with the prescribed number of rows.
