I just did 'show model annotations' and my dimension came out at an angle. How do I adjust it to lay horizontally?
It is showing the correct orientation for the item that is dimensioned, which appears to be the lenght of that side of a chamfer.
The alternative is to create the feature with a dimension from the face of the item.
Is there a drawing of that detail as part of a specification?
