Good morning fellow Creo-ites!
As you may know I am running Simulate Lite. I cannot find a way to slow down the Mpeg speed that is generated in the HTML export. Does full Simulate let you guys do that?
If I cannot slow it down I will need to "capture" it explicitly and add it to a report. Kind of a pain....actually a huge pain....but I may need to do it if I cannot do what I want within Lite.
And the title was supposed to be Export not Expert. However, both make sense!
