Whenever I complete a stretch outline and the automatic dimensions snap on, I am unable to delete or add any dimensions. I would like to be able to dimension different portions of the sketch other than changing the automatically added dimensions. In Options - Sketcher, I have been playing with the different settings to try and allow sketch dimension editing but can't seem to figure out the right setting. Thanks.
Creo always needs a fully constrained/fully dimensioned sketch. They way it accomplishes this is by adding "weak" dimensions and constraints.
The typical way to handle this is to simply add new dimensions to the sketch. The weak dimensions/constraints will autmagically start disappearing.
Generally, a good practice is to eliminate all weak dimensions/constraints so you aren't allow the software to control the geometry in some unexpected way.
Is it just this one sketch in this one part or is it any sketch in any part or assembly?
Can you share a screenshot? Maybe that will tell us something.
I've never seen it not let you re-dimension so I'm grasping at straws.
