Snap Line and Dimension Cleanup default offset values
Highlighted
Newbie
Sorry, I must be having a blackout, but I can't find where to control the
default offset values for:
* Dimension Cleanup
and
* Inserting Snaplines
Searched on my site and in the knowledge base for snap lines and clean
dimension but didn't find any relevant info.
Any ideas?
TIA,
| Olaf Corten - CAD Supervisor - Engineering
| Company: Besi Molding - Duiven - The Netherlands
| Sites: http://www.proesite.com <http: www.proesite.com="/>
| http://www.ptcuser.nl <http: www.ptcuser.nl="/>
Highlighted
RE: Snap Line and Dimension Cleanup default offset values
That would be a good thing to know. I did not know that there was any way of
controlling the default for that.
Michael P. Locascio
Highlighted
Re: Snap Line and Dimension Cleanup default offset values
If you want to change value of offset or increment for snap line than insert below value to dtl file.
default_clean_dim_increment 8
default_clean_dim_offset 5
Young Kim.
