That works! Thanks Nathan!
Thanks for the help... it worked easily...
Jus t was wondering what is the process to Split BoM to Next sheet ?
See https://www.youtube.com/watch?v=HbL2lGR6_BI
The default is to create new segments on the next sheets after you select a point for the table extent.
