Thanks to all who chimed in here to assist. There were lots of different
suggestions; some more creative that others (not surprising!).
As is often the case, the problem was one of "the forest for the trees"
syndrome. What worked?
Creating a pattern of points to use as a reference for the holes.
Creating the first hole (thru, with countersink); Pattern them; Add Hole
Pattern to the FT; suppress them (for now)
Create the second hole (threaded); Pattern them; Add Hole Pattern to FT;
Set the Y/N Criteria for the selected pattern on a per instance basis;
Verify all.
Now for a couple of interesting observations. The ultimate solution also
relied on a couple of other things I didn't know I could do.
For instance, I created the THRU holes as if threaded so I could add the
CHAMFER as a Countersink, and removing the threads. (This was somewhat
counterintuitive at first, but worked nicely). In addition, this left
me with a somewhat odd Hole Callout note, which I had to go back and
manually edit. It was also a bit surprising that I was able to Resume
BOTH sets of patterned holes without having a failure! While I'm still
not 100% sure why this is, I think it has to do with NOT having the
Chamfer feature as a child of the thru hole.
I believe that I have accomplished what I set out to do (and with
original design intent intact), thanks to the suggestions of several
people.
--Jim Augeri
MCAD Tool Support - Engineering Quality and Tools (EQT)
Honeywell Aerospace
9201 San Mateo Blvd. (MS B-3)
Albuquerque, NM 87113
Phone - 505.828.5808
Fax - 505.828.5500
james.a.augeri@honeywell.com
This e-mail message and any attachments are for the use of the intended
recipient(s) and may be controlled by U.S. export control laws. Any
unauthorized review, use, disclosure or distribution of this
communication in whole or in part without the express written consent of
Honeywell, or the U.S. Government as required, is prohibited. If you are
not the intended recipient(s), please contact the sender by reply e-mail
and destroy the original message and any copies of the message as well
as any attachment(s) to the original message.
