Superscript / Subscript Note problems
Highlighted
Hello!
I'm having some issues with a note using sub and superscript, where the note cuts of the last 2 words of two sentaces.
The sentances are as followed:
{31:4) }{32:@+Make sure there is about 0.1 mm play between part 1 and the bracket it mounts to. @#}@-Eventual protruding ring on the opposite part shall be filed away. @#
In this case, it removes the "mounts to." part of the sentence.
Has anyone sumbled upon a similiar issue? Should this be reported to PTC as a bug?
I'm running Creo 4.
BR
Jesper
Highlighted
Re: Superscript / Subscript Note problems
please ask PTC Support whether there is a text length limit for subscript/superscript.
Martin Hanák
Highlighted
My guess would be you have hit an 80 character limit in the string including control characters.
