Texture is not visible in thingworks
vbhaskar
I am trying to import mesh (.pvs/.pvz file) created in creo into thingworks but it is not showing texture.
Please advise some solution for the same
in https://www.ptc.com/en/support/article?n=CS265876 document following bug is reported:
In Creo Parametric 4.0 when exporting into a .pvz file with in recipe file, adapter/useTexture setting at the value 1, Textures are not included in the pvz file.
Martin Hanák
