Title Block Font Problem
cenglish
3-Visitor
In Wildfire 5.0, I have created a drawing Format and applied it to a lot of drawings, but on a few of them the fonts in the title block get hosed up when I export it to PDF. Somehow, the fonts are 3 times as large as they should be. For the life of me, I can't determine what is causing this to happen. There must be something in the model that is causing the issue because even if I recreate the drawing, the problem persists.
If I change the format to an older one, the problem goes away. This particular format has a table with parameter codes like &description in it. If I make a note on the drawing and export it to PDF, the parameter code is generated fine. But, the parameter codes in the title block table are 3 times too large.
Has anyone ever seen this issue? How do I resolve the issue?
Do you check the box for 'Stroke all Fonts' when exporting to PDF? Sometimes not using that option causes problems with certain things.
(IIRC there is also a config or .dtl setting that will make this selection permanent.)
Don,
That worked, I owe you a beer!
