Tool BOM
SOLVED
Gravel
Tool BOM
I‌n the tool setup there is a place to create a BOM for a tool. Is it possible to get this information out to a table on a setup drawing? If not how are people handling listing inserts etc. on their tool lists?
Tags (2)
Re: Tool BOM
Output by report tables is not implemented (yet) - I found an internal report about an enhancement type SPR, that I made public now :
CS58811 : How to get in a drawing BOM tool setup informations: "component, type and quantity" in Creo Parametric
So it seems currently the information is only output with Manufacturing Info.
Since this output is simple ascii text, it may be edited as needed and imported into a drawing note.
Re: Tool BOM
