Trailing zeros how to display in drawing
gnewman
Hello, how do i display zeros after the decimal place on dimension a view in a drawing? I have a dimension of 1 mm, but i want to display it as 1.0 to make it look better and to reflect the accuracy.
Its not significant figures as this is set as 3 for my drawing.
I have looked in File-Prepare-Drawing Properties-Detail Options.
Then I tried changing the:
lead_trail_zeros and
lead_trails _zeros_scope.
But nothing seems to make any difference. Can anyone help? Am I looking in correct area, and if so what do I need to set these two to display all the zeros as specified for my decimal places.
1 ACCEPTED SOLUTION
Creo seems to have done it itself not sure if it just needed the drawing closing and reopening.
I think it must have been in the area I suggested earlier.
KenFarley
(To:gnewman)
Pick the dimension, right mouse to "Properties".
BenLoosli
23-Emerald II
(To:gnewman)
Trailing zeros on metric dimensions violates ASME Y14.5 rules for dimensioning!
See section 1.6.1of ASME Y14.5-2009 for Millimeter Dimensioning.
Decimal places on metric dimensioned drawings are not to be used for specifying tolerancing.
