Unable to show an axis and other odd issues Creo3 M150
cpoirier
7-Bedrock
We went through a migration from WF3/Intralink 3.4 to Creo3/WC10.2.
I am working with some old data in Creo 3 Build M150.
I was unable to show an axis while updating a drawing with some moved holes.
I had to use something I have never seen before and was reported to be corrected in Creo1 M20 (CS18537)
Add user_command to delete_erased_axes
I have also seen some odd behaviour.
Rt click to flip arrows on a diameter dimension is not working and when adding an ordinate dimension all the dims go to zero??!! Hit regen and the values come back. Ordinate dim issue was not repeatable.
Is M150 a bad build?
I installed off DVD. (should not matter, but mentioned it any how)
0 REPLIES 0
